23528 Discussions
White Vertical Lines Dell Notebook
MGaun
I have a Dell notebook and recently when I turn it on it comes up with vertical white lines. I read up online and it says its a driver problem. I update to the latest driver but it still continues. If I press D + Power at the same time it comes back to a normal viewing. I have disabled the sleep and power on/off option in Windows 10. My Dell computer is a combo computer / tablet using the I7-6500 CPU @ 2500 GHz with an integrated Intel HD Graphics 520 Chip. I'm running Windows Home and the driver number is 22.20.16.4771 Any help would be greatly appreciated.
Stefan3D
Try drivers from this list https://downloadcenter.intel.com/product/88355/Intel-HD-Graphics-520 Downloads for Intel® HD Graphics 520
Select OS from right pull-down menu. Hit "show more".
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS surface)
MGaun
