22948 Discussions
Popup menus in Windows 10 are drawn blank after playing a game
Zingam
I played the game Hellblade on my laptop with Intel HD 630/NVIDIA 1050Ti graphics. I have also an external display. Before I played the game I switched off the external monitor via the Windows settings menu. After I played the game the popup menus on WIndows 10 are drawn blank. If I press for example PrtScr they are drawn properly. This issue appears only on the builtin Display - which I think is drawn by the HD630. The popup menus are drawn properly on the external display connected via HDMI and I believe are drawn by the NVIDIA GPU.
That looks like a nasty driver bug to me!
Zingam
Logging out and in - fixes the issue. The driver is the version installed by Windows Update 22.20.16.4836.
Stefan3D
Try drivers from this list https://downloadcenter.intel.com/product/98909/Intel-HD-Graphics-630 Downloads for Intel® HD Graphics 630
Select OS from right pull-down menu. Hit "show more".
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS surface)
