23810 Discussions
Why My Intel Control Panel Not Showing Properly?
FFira
Using Ivy Bridge (i5-3320M), and, the same thing is happen with my newer laptop with Haswell (i5 4210M) and my older laptop with Ivy Bridge (Pentium 2020M)...
The things i've tried to solve this problem :
  • Updating driver (No luck)
  • Remove then reinstall driver (No luck)
  • Update via Windows Update or Intel Software Updater (No luck)
Help, any answer will be appreciated...
n_scott_pearson
What driver versions are you running?
FFira
Latest, 10.18.10.5069
n_scott_pearson
I would suggest that you uninstall and then reinstall the driver package - but this time, use this process:
  1. Download latest driver package and place on system drive (on your desktop, for example).
  2. Disconnect completely from Internet (Disable Wireless and/or unplug Ethernet cable).
  3. From Apps and Features, uninstall driver package. If asked, delete all related content.
  4. Reboot (keep Internet disconnected).
  5. Install the driver package.
  6. Reboot.
  7. Reconnect Internet.
  8. Test.
Hope this helps,
