22965 Discussions
application has been blocked from accessing graphics hardware windows 10 pro
rjiki
these message always pop up when i try to play any game and and when i open nvidia control panel.
AlHill
What version of windows 10? 1903?
Sounds like you have an nvidia problem, not an intel problem. Explain in detail why this is an intel issue.
Doc
n_scott_pearson
If this is a laptop, you should not be using any drivers downloaded directly from the Intel or NVIDIA sites; you should be using *only* those drivers provided by your laptop manufacturer. It is possible that the drivers have been modified by the laptop manufacturer. Installing drivers from the Intel and/or NVIDIA sites would remove support for the custom features - and this may include (and thus block) the ability to switch between the drivers.
Hope this helps,
