23486 Discussions
Why can't I update my graphics driver?
RBrow27
I have processor: i5-6300U
Windows 10
64-bit.
Trying to update graphics driver.
Current driver: Intel(R) Graphics HD 520
Date: 01/07/2016
Version: 20.19.15.4483
I did the auto-scan thing that Intel have, and it showed me the windows 10 64 bit DCH graphics driver. However, when I try to install, I get the error "not compatible with your processor".
What driver do I need please?
Many thanks,
Ryan
AlHill
You need to remove ALL previous versions of the graphics driver, unless you are a laptop. If you are a laptop, you can use only the drivers provided by the laptop manufacturer.
If not a laptop, use this procedure. https://forums.intel.com/s/question/0D50P00004Fm2ngSAB/how-to-install-the-dch-driver?language=en_US
Doc
n_scott_pearson
I also suggest you download and install DCH driver version 25.20.100.6618 or newer. These versions (finally) have support for over-installing older non-DCH driver versions.
RBrow27
I am a laptop - HP laptop.
I cant seem to install amything "compatible"
What should I do next?
AlHill
You need contact HP for support.
HP is solely responsible for support of your laptop.
Doc
n_scott_pearson
For laptops - and especially when talking about graphics drivers - you should only be getting your drivers from your laptop vendor.
