22839 Discussions
Why do blue lines appear on my screen?
JCarl34
bluelines.PNGRecently, with the update of the driver of my intel gpu (intel hd graphics 620) I am having this type of problem almost in anything of my second monitor, before installing the new driver nothing happened, now it is very annoying, even when I play I can notice it. What's going on?
AlHill
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
JCarl34
That is what I save, I hope and it helps you to solve this 🙂
Wanner_G_Intel
Hello JCarl34,
Thank you for posting your question on this Intel® Community.
To better assist you, we would like to have more information about your system configuration:
  • Could you please confirm if this issue happens on the built-in monitor as well? If not, how are you connecting the external monitor to the laptop? Are you using adapters?
  • Does the issue continue to happen if you roll back the driver? 27.20.100.8190 or the driver provided by Acer: 23.20.16.5038
  • Are you able to attach a short video of the issue? Could you please attach another picture showing the issue?
  • Generate a DxDiag* report and attach it.
  1. Go to Start > Run or Windows Key + R.
  2. On the Run prompt, type "dxdiag" then click OK.
  3. On the DirectX Diagnostic Tool window, click on Save All Information.
  4. Browse to a folder, type in a filename then click Save.
Wanner G.
Wanner_G_Intel
Hello JCarl34,
If you need further assistance, please let us know. We will be glad to help you.
Wanner G.
IntelSupport
Community Manager
Hello JCarl34,
We have not heard back from you, so we will close this inquiry. If you need any further assistance, please post a new question. We will be glad to help you.
Wanner G.
