22850 Discussions
Why does Windows 10 limit my monitor resolution to 1080
ABywa
I have the following setup but am unable to set set my display resolution to anything above 1080 when using Windows. I believe the issue is caused by limitations with the CPU as it states that HDMI only supports up to 1080.
https://ark.intel.com/products/82723/Intel-Pentium-Processor-G3258-3M-Cache-3_20-GHz Intel® Pentium® Processor G3258 (3M Cache, 3.20 GHz) Product Specifications
My only issue with this is my computer is dual boot, and why I boot into Ubuntu with exactly the same setup, I can select 2560 x 1440 without any issues. So why does Windows not offer this?
Andy
Monitor: AOC Q3279VWF - supports up to 2560 x 1440 (75p Hz)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: Z97P-D3
BIOS: BIOS Date: 05/30/14 09:03:04 Ver: 04.06.05
Processor: Intel(R) Pentium(R) CPU G3258 @ 3.20GHz (2 CPUs), ~3.2GHz
Memory: 8192MB RAM
Intel(R) HD Graphics
Report Date: Thursday, January 18, 2018
Report Time [hh:mm:ss]: 4:40:19 PM
Driver Version: 20.19.15.4835
Operating System: Windows* 10 Pro (10.0.16299)
Default Language: English (United States)
Physical Memory: 8085 MB
Vendor ID: 8086
Device ID: 0402
Device Revision: 06
Video BIOS: 2179.0
Current Resolution: 1920 x 1080
Processor Speed: 3200 MHz
Processor Graphics in Use: Intel(R) HD Graphics
Shader Version: 5.0
OpenGL* Version: 4.3
OpenCL* Version: 1.2
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 11.1
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Digital Television *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 28.74 inches
Vertical Size: 16.93 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (67p Hz)
640 x 480 (72p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60p Hz)
720 x 576 (50p Hz)
800 x 600 (56p Hz)
800 x 600 (60p Hz)
800 x 600 (72p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (70p Hz)
1280 x 720 (50p Hz)
1280 x 720 (60p Hz)
1280 x 960 (60p Hz)
1280 x 1024 (75p Hz)
1280 x 1024 (60p Hz)
1280 x 1440 (60p Hz)
1440 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (60i Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (60p Hz)
2560 x 1440 (60p Hz)
Power Management Support
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 05 E3 79 32 FB 0E 00 00
29 1B 01 03 80 49 2B 78 2A 79 E5 AC 51 44 AC 26
0F 50 54 BF EF 00 D1 C0 B3 00 95 00 81 80 81 40
81 C0 01 01 01 01 56 5E 00 A0 A0 A0 29 50 30 20
35 00 D5 AC 21 00 00 1E A0 73 00 6A A0 A0 29 50
08 20 35 00 D5 AC 21 00 00 1A 00 00 00 FD 00 30
4C 1E 72 1E 00 0A 20 20 20 20 20 20 00 00 00 FC
00 51 33 32 37 39 57 47 35 42 0A 20 20 20 01 A6
02 03 29 F1 4B 10 1F 05 14 04 13 03 12 02 11 01
23 09 07 07 83 01 00 00 67 03 0C 00 10 00 38 3C
68 1A 00 00 01 01 30 4C 00 02 3A 80 18 71 38 2D
40 58 2C 45 00 D5 AC 21 00 00 1E 8C 0A D0 8A 20
E0 2D 10 10 3E 96 00 D5 AC 21 00 00 18 8C 0A D0
90 20 40 31 20 0C 40 55 00 D5 AC 21 00 00 18 F0
3C 00 D0 51 A0 35 50 60 88 3A 00 D5 AC 21 00 00
1C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C4
* Other names and brands are the property of their respective owners.
Hello, Bang0,
I understand that you have been facing issues in order to set up a specific resolution in Microsoft* Windows*, let me help you out with this.
I could see that your current driver version that you have installed is the latest one. Moreover, I would like to suggest you test in Microsoft* Windows* a different driver version.
Please check below the link in order to find the different version for your Onboard Graphics of this processor:
https://downloadcenter.intel.com/search?keyword=+Intel%C2%AE+HD+Graphics+for+4th+Generation+Intel%C2%AE+Processors https://downloadcenter.intel.com/download/27414/Beta-Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-
Also, please test a different HDMI cable in order to check that the issue is not related to the cable.
I will be waiting for your outcome.
Emeth O
ABywa
Hi I have tried the beta driver and different HDMI cable and still am unable to select a resolution above 1080.
I was doing some research on this issue on my end I found that if you proceed with a Custom Resolutions you might have the chance to set up the resolution that you would like in windows* manually. I will share with you an article of intel if you would like to know more information about this. Please check the link below:
https://www.intel.com/content/www/us/en/support/articles/000005540/graphics-drivers.html https://www.intel.com/content/www/us/en/support/articles/000005540/graphics-drivers.html
Also, I would like to share with you an article is not from Intel moreover it has some important steps in order to set up properly a Custom Resolution in your system. As well, you will notice that the issue that you have been facing is very similar to the issue mentioned in the article. Please check the link below:
https://www.notebookcheck.net/2560x1440-or-2560x1600-via-HDMI.92840.0.html https://www.notebookcheck.net/2560x1440-or-2560x1600-via-HDMI.92840.0.html
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Emeth M
I would like to know if the issue still persists or if you could figure out the solution to the issue.
Please, if you have any question do not hesitate and let me know.
Emeth O.
ABywa
I've added custom resolutions but when I select one the screen goes black and I get a message stating input not supported.
Andy
Hi, Bang0,
Could you please provide me in which specific resolutions did you receive the error?
it happens with all the custom resolutions or just with a specific one?
When you tried to set up the customer resolution; which option did you select in Timing Standard? Also, in the refresh rate which one did you choose?
Could you please set up the resolution in this way just to test?
By the way, have you ever tried to set up that resolution in safe mode?
Emeth O.
I would like to know if the issue still persists or if you will need more assistant with this issue?
Emeth O.
