22958 Discussions
Why intel graphic 4600 is not working on windows 10?
balho
i'm using hp omen and since i have upgraded to windows 10 i started having major problems with my intel graphic card, it keeps on crashing specially when i work on Autodesk programs, even when i try to use skype... is there any solution for this issue?
Bryce__Intel
Hey Bashir_Alhomsi,
Please check out the /thread/77761 sticky for reporting issues. This includes checking if existing issues are already reported in the forums and if not following the guidelines for submitting your inquiry so others on the forum can best help answer your questions. The Intel crew will address it with no one else has an answer.
Allan_J_Intel1
Please fill out the sticky form and the Intel Customer Support team will help you on this matter.
Allan.
