23525 Discussions
Why is Intel DSA showing two different graphics drivers? (Arc vs. 11th-14th Gen)
Ruban-31
Hey everyone, I'm using an MSI Thin GF63 12HW and I'm a bit confused by the Intel Driver & Support Assistant. It’s prompting me to install two separate graphics updates:
  1. Intel Arc Graphics - Windows
  2. Intel 11th - 14th Gen Processor Graphics - Windows
Won't these two drivers clash if I try to install both? Specifically, if I choose a "Clean Installation" for one, will it wipe out the other?
My laptop has an Alder Lake CPU (12th Gen) and an Intel Arc dedicated GPU. Should I be installing both of these, or is one intended to override the other? Any advice on the proper installation order would be greatly appreciated!Screenshot 2026-02-22 133613.png
AlHill
Your concerns are very valid and correct.
Yes, you should install both, but install the 11th-14th driver first (and you can do a clean install if you want).
Then, install the arc driver, but do not do a clean install.
Personally, I install the 11th-14th gen from this link (thus avoiding IDSA and its problems):
https://www.intel.com/content/www/us/en/download/864990/intel-11th-14th-gen-processor-graphics-windows.html
Then, I install the arc  driver from this link:
https://www.intel.com/content/www/us/en/download/785597/intel-arc-graphics-windows.html
This works correctly on my 12th gen nuc.
It is a pity that Intel graphic driver developers handled this so poorly.
[CoPilot is a virus, W11 is a keystroke logger, all from MicroSlop]
AlHill
Ruban-31
Thanks man it worked!
Also while we are here can you like tell me how i can disable windows auto graphics update i tried eveything but it keeps rolling back to older version of GPU drivers
AlHill
To stop windows update overwriting your driver, download the microsoft wuShowHide tool and save it.
Then, after  updating to the driver of your choice, run the wuShowHide tool and block/hide the microsoft update that you do not want.
This works for most users, but may not work for all.
Ruban-31
Worked! thanks a bunch brother
Ruban-31
Uninstalled Copilot a long time ago, Big hater of W11 btw (W7 ultimate for the win)🤣
