23106 Discussions
Why is my CS: GO FPS drop?
CUdan
I've been noticing huge FPS drops while playing CS: GO. It stays at 60+ FPS most of the time and suddenly drops to 10-20 FPS and comes back to 60+ after several seconds. I'm not sure why, it would be great if anyone can help me. I've updated my drivers to the latest and DirectX as wellFP
Kevin_M_Intel
Hello Awesomness,
Can you please post your dxdiag system information?
CUdan
Here are my dxdiag system information:
System Information
Time of this report: 5/24/2013, 12:34:15
Machine name: CHAMOD-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Inspiron N5050
BIOS: BIOS Date: 03/23/12 14:35:39 Ver: 04.06.04
Processor: Intel(R) Core(TM) i3-2370M CPU @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 6144MB RAM
Available OS Memory: 6052MB RAM
Page File: 2512MB used, 12537MB available
Windows Dir: C:\windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
Kevin_M_Intel
Hello awesomness,
Thanks for the information.
Note that the drivers we have are generic drivers and we recommend installing the drivers from the system manufacturer side. However, you can try from our side installing the latest graphics driver for the Intel® HD Graphics 3000 at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22628&lang=eng&OSVersion=Windows%207%20%2864-bit%29*&DownloadType=%0A%09%09%09%09%09%09%09Drivers%0A%09%09%09%09%09%09
As part of the troubleshooting steps we can recommend you, is to update all the drivers using the drivers from the system manufacturer side including the BIOS chipset.
VStri
Hello!
I have THE SAME PROBLEM! I have 120fps but randomly they go down, for just a fraction of a second, to 50, 60 then back to 120. Why is that?
I will give you all the info you need just tell me what.
CVale10
RonanN1
It sounds like you may be experiencing common gameplay. Remember the entire game isn't loaded into memory or onto the graphics chip. During the game scenes with high action, new textures being loaded, or just additional players entering the game can drop your FPS down a bit. Especially if it for just a fraction of a second. If you gameplay is really affected the previous advice should be taken. If there is a benchmark for that game I suggest you run it and post the results.
Chase Valentine
