23525 Discussions
Will there be a HD Graphics driver in the future that supports HDMI 2.0?
TIbra
On my PC there is only an output of HDMI (HD graphs 520). I want a 4K resolution of 3840 x 2160 with 60 frames.
Hello HerzogZwei,
Thank you for joining the Graphics Community.
Supporting a version of HDMI is a matter related to hardware not software, the Intel® HD Graphics driver itself will not update the HDMI version. But, once installed it will recognize the version that your system includes.
Amy C.
TIbra
Will 60Hz work with the HDMI to DP adapter? (for the resolution of 3840 x 2160).
You will need to double check with your computer manufacturer if this specif model can help to achieve the resolution in question.
What is your processor model? I would like to check the supported resolutions.
Amy C.
TIbra
Thank you for your help! My computer firm "Hystou" with a processor i-3 6100U. Same as this photo.
Based on your processor model these are the maximum supported resolution:
Find the specification here: https://ark.intel.com/products/88180/Intel-Core-i3-6100U-Processor-3M-Cache-2_30-GHz Intel® Core™ i3-6100U Processor (3M Cache, 2.30 GHz) Product Specifications
According to your device specification, it supports ultra HD 4K resolution. http://www.hystou.com/products/fanless-mini-pc/intel-6th-gen-mini-pc/newest-intel-gen-i3-6100u-fanless-mini-pc-thin-client-computer-case-with-2g-ram-128g-ssd-2542.html Newest Intel Gen i3 6100U Fanless Mini PC Thin Client Computer Case with 2G RAM 128G SSD
Amy C.
TIbra
What you wrote I know. HDMI 1.4 = 3840x2160 30hz. Is it possible to make the output of HDMI work like DP?
The HDMI output cannot work like the DP output.
Amy C.
TIbra
Can I get HDR with this adapter? Will there be a big delay? How many milliseconds?
https://www.amazon.com/gp/product/B075HM6YLZ/ https://www.amazon.com/gp/product/B075HM6YLZ/Plugable USB 3.0 Dual 4K DisplayPort Adapter with Gigabit Ethernet for Windows (Supports Two DisplayPort Displays up to 3840x2160@60Hz, Windows 10, 8.1 & 7)
RonaldM_Intel
Hello HerzogZwei,
We only support native HDR starting on Kaby Lake (7th Generation) processors if the connection is HDMI 2.0a or DP 1.3. The DisplayPort (DP) adapter that you are indicating is DP 1.2, therefore HDR won't work. More so, the DP output on your computer must be DP 1.3 as well.
For further questions on Intel's HDR support I suggest looking at the following white paper: https://www.intel.com/content/dam/support/us/en/documents/graphics/HDR_Intel_Graphics_TechWhitePaper.pdf https://www.intel.com/content/dam/support/us/en/documents/graphics/HDR_Intel_Graphics_TechWhitePaper.pdf
Kindest Regards,
Ronald M.
