22661 Discussions
Win8 CP, GMA 3600 Drivers crashing under metro
Hi Guys,
I am using a toshiba WT200 that has an intel GMA3600 video chipset. When you launch metro apps, the sys file from the driver causes a BSOD. I have tried this microsoft OLE fix, but to no avail (see http://social.technet.microsoft.com/Forums/en-US/w8itprogeneral/thread/b0e4f9a3-4c96-4e6f-9399-71fc5813853c Metro apps won&# 39;t start under consumer preview of Windows 8 )
Is there a beta driver suitable for this device coming, that will alleviate this issue?
Thanks, Chris
Kevin_M_Intel
Guys,
I am sorry to hear you are having problems with your products. At this point the drivers we have for the controller GMA 3600 is for win 7 32 bit only.
If you are having problems installing drivers In the HD 4000 graphics controller, you can try the manual driver installation. Here are the steps:
http://www.intel.com/support/graphics/sb/CS-022355.htm http://www.intel.com/support/graphics/sb/CS-022355.htm
Sometimes, OEMs set software limitations for their units and that is way is very important to install the drivers provided by the computer manufacture.
MH9
Kevin,
Will Intel GMA 3600 (http://www.intel.com/p/en_US/support/highlights/graphics/gma3600 Support for the Intel® Graphics Media Accelerator 3600 Series) ever be able to run Windows 8.1 Pro 32bit without crashing metro applications?
MH9
FYI
Nome do registo:System
Origem: Microsoft-Windows-Kernel-Power
Data: 03/01/2014 13:18:08
ID do evento: 41
Categoria de Tarefa:(63)
Nível: Crítico
Palavras-chave:(2)
Utilizador: SYSTEM
Computador: recepcao-pc
Descrição:
O sistema foi reiniciado sem primeiro ter sido encerrado de forma correta. Este erro pode ter ocorrido porque o sistema parou de responder, sofreu uma falha ou ficou sem energia inesperadamente.
Evento Xml:
http://schemas.microsoft.com/win/2004/08/events/event">
41
3
1
63
0
0x8000000000000002
239
System
recepcao-pc
278
0x84806008
0x96c0b0df
0x0
0x2
0
0
0
Enviado de Correio do Windows
MH9
MH9
Amazingly on Linux atom n2600 with gma 3600 runs flawlessly!!!
Kevin_M_Intel
I am sorry miguEl but at this point Intel® has no plans to release GMA 3600 Drivers for Win 8 or later.
ANauf
Hi Kevin,
If Intel ® there are no plans to make GMA 3600 Drivers for Win 8 or later. Why not make plans to release the GMA 3600 Drivers for Win 8 or later?
Sorry for bad english, I use translator.
Kevin_M_Intel
I am sorry, but Intel® will not be releasing Windows* 8 drivers for GMA 3600.
FFeit
Olá
Primeiramente, desculpe-me por reviver um tópico antigo.
Fazendo alguns testes com um driver não oficial, consegui abrir alguns apps Metro na GMA 3600 com o Windows 8.1 Update 1.
O driver pode ser encontrado em uma página do Facebook com o nome Intelli Modder 32 e o driver para GMA 3600 chama-se PHDGD Yankee 1.0 x86. É um arquivo sem extensão que pode ser descompactado pelo Winrar ou 7-zip.
Após a instalação reiniciem o computador e quando iniciar façam o procedimento de alteração no regedit na chave display1_downscaling_supported alterando o valor Hexadecimal para 1 e reiniciem novamente o computador.
Após a reinicialização, tentem abrir os apps Metro.
Eu também fiz por minha conta uma alteração nas configurações avançadas do Internet Explorer 11, marcando uma opção na aba Avançadas por nome 'Elementos gráficos acelerados' (Usar renderização de software, em vez de renderização por GPU), visto que acho que os problemas de BSOD são causados por alguma API do Internet Explorer 11 responsável pela renderização. Acesse as configurações de Opções da Internet através do Painel de controle, caso não consigam abrir o Internet Explorer. OS apps Metro devem usar a API do IE 11 para exibir informações da internet.
Vejam as imagens:
Kevin_M_Intel
Falvesf,
I am sorry but Portuguese is a language I do not understand yet. Can you please post it in English?
FFeit
oh, sorry
My English is bad too ... but will try to answer you with a translator.
What I meant is that I tested an unofficial driver and through him some Metro apps work.
I showed some screenshots of apps running and I put some instructions if someone wants do the test.
The unofficial driver is on facebook community Intelli Modder 32 - Modded Drivers for Intel -> https://www.facebook.com/modpgd?ref=stream&filter=3 https://www.facebook.com/modpgd?ref=stream&filter=3
Kevin_M_Intel
Oh I see, well thanks for the information. I am sure this will be helpful to other customers.
