Annonces
23484 Discussions
Windows 10 Ver 1607 64 bit driver for intel HD graphics 3000
VVive3
Débutant
30 631 Visites
Hi All
I have a HP dv6-6016tx laptop with 2 display adapters in the display manager:
  1. AMD Radeon HD 7400M
  2. Intel HD Graphics 3000
When I first updated to windows 10, the screen would go blank for about 45 seconds while starting up and resuming from sleep. I fixed this by setting the EnableULPS registry key to 0. I think this just disabled the Intel Driver.
When I updated to Windows 10 ver 1607, I found that AMD Catalyst had been uninstalled (possibly not compatible) and the blank screen problem returned.
Now when I open device manager the driver details of Intel HD Graphics 3000 are:
Driver Version: 9.17.10.4229 Dated 05/27/15 Provided By Intel.
The driver on Intel website is for Windows 7 & 8 Only
Date: 05-Jun-2015 Version: 15.28.24.64.4229 (Latest) OS: Windows 7, 64-bit*, Windows 8, 64-bit*
I want to know whether I can install the above driver on Windows 10 ver 1607 (64 bit) Build: 14393.321 and whether the blank screen problem will go away.
Thanks is advance for your reply.
VS
0 Compliments
9 Réponses
AlHill
Super utilisateur
28 341 Visites
HD Graphics 3000 is not supported on Windows 10:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products
Doc
0 Compliments
Employé
28 341 Visites
Hello VS228,
Correct, Intel HD Graphics 3000 is not supported for Windows 10*
The driver 4229 is the latest available for Windows 8.1*
You could disable each of the graphics adapters in the device manager to find out which works the best.
I apologize for any issue this may have caused!
Esteban C
0 Compliments
FMart22
Débutant
28 341 Visites
Hi VS228, try this drivers Catalyst 16.2.1 UnifL: http://leshcatlabs.net/forums/showthread.php?tid=1176 http://leshcatlabs.net/forums/showthread.php?tid=1176
The drivers are up to date to May 30, 2016 - Intel v.10.17.10.4229, AMD v.16.301.1901.0
I use them on my laptop with Windows 10 Pro x64 v1607 14393.447, AMD Radeon HD 6700M and Intel HD Graphics 3000 and works fine.
0 Compliments
Employé
28 341 Visites
Thank you for the information provided, Francisco77
Please note these are not official drivers and Intel does not fully recommend using them, VS228 .
Esteban C
0 Compliments
FMart22
Débutant
28 341 Visites
Hi Esteban, I understand, but Intel does not provide support for dual graphics card, only the manufacturer, like HP in this case.
So, my recommendation is based in my experience because I had a similar problem and these drivers worked for me on Windows 10.
0 Compliments
Employé
28 341 Visites
Yes, I understand your point, Francisco77
I just wanted to make things related to support clear in order to avoid misunderstandings 🙂
In case you require any further questions answered in the future, feel free to reach us here or any other support platform.
Hope you guys have a great week!
Esteban C
0 Compliments
VVive3
Débutant
28 341 Visites
Is it compatible with AMD Radeon HD 7400M?
Installation instructions would be greatly appreciated.
Thanks and regards
VS
0 Compliments
FMart22
Débutant
28 341 Visites
UnifL stands for `Unified Leshcat Drivers`.
Those drivers are based on latest AMD + Intel Drivers and aimed to support laptops (and Desktops too) powered with:
• AMD 5xxx/6xxx/7xxx/8xxx/Rxxx Series
• Intel HD/HD2000/HD2500/HD3000/HD4000/Iris/Haswell/Broadwell CPU Embedded Graphics
UnifL drivers are designed and tested on x64 versions of Windows 7/Windows 8.1/Windows 10,
however it should work on Server Editions (i.e: Windows Server 2008) as well.
Unified Leshcat Driver Manual v1.5.2 11.01.2016: http://leshcatlabs.net/manual_chm/ http://leshcatlabs.net/manual_chm/
I hope it helps.
Francisco77
0 Compliments
Employé
28 341 Visites
Thanks for the information shared, Francisco77
Esteban C
0 Compliments
Répondre
