23719 Discussions
Windows 10, multi Monitor, maximized window blank/empty space on top of screen.
SJapa
We have different Users with a strange behaviour - if they maximize a window tested with IE11, Acrobat, Windows Explorer, google chrome they get an empty or black / white space on top of that window.
Right clicking on the empty or black / white space on top of that window you get the context menu of the desktop.
It's just when the window is maximized, you can stretch it to "full screen" by hand and its fine too. maximize > problem appears.
Users have dual screens
if the user signs out, and signs back in it works.
if i disconnect the user from the session and they log back in it works.
if i connect to the session with one screen it works.
CTRL+SHIFT+WIN+B and signs back in it works.
Problem occurs with notebook and multi-vendor desktops with ou without offboard video card.
Occurs with HD graphics:
Intel® HD Graphics 630
Intel® HD Graphics 530
Intel® UHD Graphics 620
Problem reported and known by other users:
https://answers.microsoft.com/en-us/windows/forum/windows_10-update/windows-terminal-server-2016-multi-monitor/aefbec87-0f5e-4f35-8296-b432d7d7f98b?tm=1538402889026&rtAction=1538550302665
https://answers.microsoft.com/en-us/windows/forum/all/windows-10-pro-missing-title-bar-and-part-of-the/3a16d7d2-a212-42cd-8f57-b9255a4a15e5
https://productforums.google.com/forum/#!topic/chrome/kztvALbicwE;context-place=forum/chrome
https://answers.microsoft.com/en-us/windows/forum/windows_10-files/white-bar-covering-top-portion-of-windows-explorer/958e89c3-22ea-48d8-aeaf-bac25d11aa94
#TAG:
white bar covering top portion of windows explorer
white bar in top or bottom window when maximized
white bar across top of maximized
white or black bar across top of maximized
Wanner_G_Intel
Hello all, We have not been able to reproduce the issue described on this thread. Our tests were performed on the following hardware: * Intel NUCi7DNKE: Windows 10 (17763) driver 25.20.100.6577 * Lenovo T480: Windows 10 (16299) driver 23.20.16.4901 Steps followed: 1. Clean Windows 10 installation with just Chrome and Outlook 2016. 2. Connected two monitors (Acer B286HK and Acer G257HU). 3. Set both monitors in Extended display via Intel Graphics Control Panel. 4. Launch several instances of File Explorer, Chrome and Outlook 2016. 5. Maximize each window. 6. Minimize each window. 7 Move the windows to the 2nd monitor. 8. Repeated steps 5-6 several times. No issue was observed. Windows are displaying correctly. Some threads are referencing this issue and some users with non-Intel Graphics are also reporting this issue. Examples: https://www.reddit.com/r/sysadmin/comments/8imjva/windows_10_multi_monitor_maximized_window/ https://answers.microsoft.com/en-us/windows/forum/all/windows-10-pro-missing-title-bar-and-part-of-the/3a16d7d2-a212-42cd-8f57-b9255a4a15e5?page=12 This seems to be an operating system related issue that may be triggered by a particular update. If the issue persists, we recommend reporting this issue to Microsoft*. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
Amy_C_Intel1
Hello SJapa, Thank you for posting on the Intel® Communities. When did the issue start? What are the conflict driver versions? How many units are affected? What are the computer models? What is the Windows 10 build installed in each computer? Amy C Intel Customer Support Technician Under Contract to Intel Corporation
SJapa
~June 2018.
What are the conflicitic driver versions?
23.20.16.4973, A06
23.20.16.4905,A04
22.20.16.4836,A05 10
22.20.16.4771,A04 16
21.20.16.4627,A03 04
21.20.16.4565,A02 24
21.20.16.4542,A01 25
+ 1000 unit (multi-vendor).
Various, Dell (Optiplex 3050, 3040, Inspiron 7572), HP (ProDesk 400 G3 Mini, HP Z240 Tower Workstation), Lenovo.
1803 and 1809.
PGame
Hello guys
I'm also having the same problems
Any solution already?
MEdua2
Hi guys!
I'm facing the same problems.
Is there any ETA for solution?
Amy_C_Intel1
The drivers you mentioned seem the versions provided by the computer manufacturers. Is the issue present in your environment with drivers from our Download Center? https://downloadcenter.intel.com/product/98909/Intel-HD-Graphics-630 https://downloadcenter.intel.com/product/88345/Intel-HD-Graphics-530 https://downloadcenter.intel.com/product/126789/Intel-UHD-Graphics-620 Have you tried with a Windows roll back? Amy C Intel Customer Support Technician Under Contract to Intel Corporation
SJapa
AmyC,
Driver installation generates error stating not to be compatible:
"Error: The driver being installed is not validated for this computer. Obtain the appropriate driver from the computer's manufacturer. Setup will exit.
Or
Error: This driver could not be installed on this computer. Contact the computer's manufacturer for further information".
dch_win64_25.20.100.6471.exe
https://downloadmirror.intel.com/28435/a08/dch_win64_25.20.100.6471.exe
Article ID: 000005469
https://www.intel.com/content/www/us/en/support/articles/000005469/graphics-drivers.html
Windows roll back is not possible.
The Intel driver dont approved for Windows 10 (1803 and 1809)?
*Other users have the same problem.
Shibby
I have been seeing the same behavior for several users. Changing the following configuration used to be a fix a while ago, but doesn't look like it is anymore:
Go to Intel Graphics Control Panel / Display / General Settings / Tick Scale Full Screen / Tick override application settings / Apply.
I see it all around several forums, but still no valid solution has been provided and doesn't look like a single manufacturer issue as different vendors are facing the same behavior.
Amy_C_Intel1
In that case you can try updating the driver using the https://downloadcenter.intel.com/download/24345/Intel-Driver-Support-Assistant and also running Windows 10 updates. You will need to check with Microsoft if the specific update comes with the latest DCH driver. Version 25.20.100.6471 is supported on 9th Generation Intel® Core processors, 8th Generation Intel® Core processors, 7th Generation Intel® Core processors, 6th Generation Intel® Core and Intel® Mobile Xeon processors and related Pentium/Celeron: • Microsoft Windows* 10-64 - Fall Creators Update (1709) • Microsoft Windows* 10-64 - April 2018 Update (1803) • Microsoft Windows* 10-64 - October 2018 Update (1809) Amy C Intel Customer Support Technician Under Contract to Intel Corporation
SJapa
Functional equipments with driver 21.20.16.4542 (Release date 25 Jan 2017) pointed manually.
All new versions have the bug.
Amy_C_Intel1
Thank you for that information. We recommend you to stick with that driver version. I will report this to the product team. For future driver releases visit https://downloadcenter.intel.com/ Amy C Intel Customer Support Technician Under Contract to Intel Corporation
SJapa
AmyC,
Unfortunately bug persists with the driver 25.20.100.6577 Beta.
Workaround testing also no longer works. Old version 21.20.16.4542 the bug is also occurring.
Amy_C_Intel1
We wanted to follow up this matter. If you need further assistance let us know. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
ZNyki
I also occur this bug and can't install previous driver - 8th generation Intel.
Can you suggest something?
It mostly happenes when we use office apps on network shares.
Amy_C_Intel1
Please, help us to track his behavior by creating a new thread. Add all you information on a new thread, you can take this thread as reference. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
SJapa
Using the old drvier is not a solution.
Windows update updates it frequently and we have to repeat the driver downgrade process.
Does Intel have a new driver forecast?
Other users persist with the problem.
https://answers.microsoft.com/en-us/windows/forum/all/windows-10-pro-missing-title-bar-and-part-of-the/3a16d7d2-a212-42cd-8f57-b9255a4a15e5? language = en_US & page = 9
Amy_C_Intel1
SJapa, I have not heard back from you so I will close this inquiry now. If you need further assistance, please post a new question. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
SJapa
Amy_C_Intel1
We would need clear steps to reproduce the issue. Perhaps, you can record a video where we can see the steps to reproduce and the issue itself showing up. Also require the DxDiag.txt and Graphics report from a failing system in order to capture important details. In addition, is it only with multi-monitor configs? Does it have to be Extended or clone? https://www.intel.com/content/www/us/en/support/articles/000005848/graphics-drivers.html Amy C Intel Customer Support Technician Under Contract to Intel Corporation
SJapa
Attached is the video of the problem.
SJapa
Attached Dxdiag
