22928 Discussions
Windows 7 fails to see drives in Disk Management / Device Manager for RAID5 volume on ICH10R on ASUS P5Q-Pro
I have a 4x500GB RAID 5 Volume performing VERY slow even with write cache enabled (~15MB/s R & W). I am running Windows 7 32-bit. The system does see the RAID controller and I am using 8.9.0.1023 drivers. However, I am unable to see the RAID volume in Device Manager and Storage/Disk Management in the Computer Management MMC. Everything was fine and fast when before I upgraded this comp from Windows XP SP3. Any help will be appreciated.
Also: I AM able to see the RAID5 volume in Windows Explorer...
Maybe the array is rebuilding and that's why the slow speed.
Did you check the array status with the storage manager console ?
The array is in a normal state.
