23769 Discussions
Windows 8 - Intel HD Graphics - HDMI Output
Anyone any idea how I can get the HDMI output working on my system? I am assuming there is no official support yet as Intel Update Utilities have drawn a blank.
Device ID : PCI\VEN_8086&DEV_0046&SUBSYS_21C817AA&REV_02
Operating System : Windows 8 x64
Driver installed : Intel HD Graphics WDDM 1.1 ver 8.15.10.2702
Many thanks in advance for any replies
Dave
I downloaded the 64 bit version test driver - http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21840 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21840 , unpacked en used setup to install.
That does NOT work, I got a windows with the header "Error" and the message:
This computer does not meet the minimum requirements to install the software.
I am running Starry Night Pro Plus 6.
Windows 8 tells me I have the following Display adapter: Intel(R) HD Graphics (Microsoft Corporation - WDDM 1.1)
Shuttle SH55J2:
PROCESSOR
Intel Core i5 661 processor
LGA1156 socket
Note: Please choose processors with Intel HD Graphics technology to utilize on-board graphics function.
This is what I use, as wel in Win7 as Win8.
CHIPSET
Intel H55
MEMORY
DDR3 1066/1333 MHz support, over clock to 1600 MHz (TBD)
RAM Socket * 4, 2 channels support (2+2)
System DDR3 1066/1333 Mhz 16 GB total (4GB*4).
What do I have to do in order let Starry Night run?
I have the exact same problem. HDMI output was working just fine, then I upgraded to windows 8 and now it will not work. I have tried installing the new driver and I receive the same error message:
Here is what I am running
Adapter Type: Intel(r) HD Graphics (Microsoft Corporation - WDDM 1.1)
Chip Type: Intel(r) HD Graphics (core i5)
Thanks for the replies.
Unfortuantly the test driver will no install on my machine either i get the same message:
ROBERT_U_Intel
Hi Gaz
What chipset is on your system?
MSchm21
Valued Contributor I
DEV_0046 belongs to HD first generation graphics, means not supported for Windows 8 generic drivers.
