23529 Discussions
Windows defender showing Drivers incompatibility
JoyfulGlory
Hello Community,
My windows defender showing yellow mark saying incompatibility of drivers.
How can I solve this issue?
JoyfulGlory.
AlHill
Turn off core isolation.
https://support.microsoft.com/en-us/windows/why-do-incompatible-drivers-prevent-using-memory-integrity-0b7ae567-74de-ee03-1030-9e6fe0d6f4b6
JoyfulGlory
No SIr,
Problem not solved.
LeonWaksman
Hi JoyfulGlory
1. To fix the ssudbus.sys ssudmdm.sys error:
     1.1 Open File Explorer, then navigate to C:\Windows\System32\drivers
     1.2 Search for the two problematic drivers and rename them, adding .old extension.
     1.3 Reboot your computer.
2. To fix the igdkmd64.sys error:
     2.2 Open the Device Manager and then open the Display adapters tab.
     2.3 Right click on Intel Display Adapter and then click on Uninstall Device (check "Attempt to remove...")
    2.4  Reboot your computer and check that you see now Microsoft Basic Graphics Driver in place the Intel Graphics Driver. If not yet, repeat para. 2.3 and 2.4.
    2.5 Check in C:\Windows\System32\drivers that you don't see any igdkmd64.sys file.  If such driver exists, rename it to .old.
    2.6 Now the error should disappear and you are ready to download and install the compatible Graphics Driver from your computer OEM site.
Leon
