Hi.
I'd like to use Windows server 2016 Multipoint services.
Configure mode should be changed into Station mode in Multipoint manager to assign sub-monitor to host PC via Zero Client.
But Configuration error shows as below.
Could you give me advice to solve this issue based on the info I captured?
Graphic driver is set microsoft basic display adaptor...
Hello JCE1313,
In order to better assist you with this issue, could you please confirm if this error appears after boot up?
I look forward to hearing from you.
Steven G.
Steven G.
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
