I have Dell XPS13, with
Intel i7-5600U CPU 2.60GHz and
Intel HD Graphics 5500, Driver version 20.19.15.4531, Driver date 29/09/2016.
I need set resolution 2560x1080 for LG Ultrawide.
Can someone confirm if is posible?
Tanks.
Coincidentially i have a similar hardware combo, an Acer laptop though.
Should be close enough.
Power on monitor, then hot plug the HDMi cable, before monitor goes into energy save mode again.
Stefan3D, thanks for your advice.
In my case, Intel HD 5500 accept 2560x1080 50p Hz but no 59p Hz or 60p Hz.
In your screenshot refresh rate is 59p Hz.
Did you make another configuration in your system?
59p is default on my rig.
I can select 60p from pull-down menu and have to confirm the change.
