23081 Discussions
Your computer does not meet the minimum requirement for installing the software.
MOCTA
Your computer does not meet the minimum requirement for installing the software. Today i just buy Acer ES1-511-C3KV i download the auto update infinity tool to instal graphic driver , the tool download the driver but i got that error WHAT I NEED TO DO I DONT HAVE THE GRAPHIC OPTION IN BIOS. I have windows 7 32 bits
Silvia_L_Intel1
Hi MariusGaius
Could you please attach the DX Diag report for your system? (Start -> Run -> dxdiag -> Save All Information).
The following URL will give you some steps you can follow in order to solve the error you are getting "System does not meet minimum requirements"
http://www.intel.com/support/graphics/sb/CS-034659.htm http://www.intel.com/support/graphics/sb/CS-034659.htm
АТолм
Help please!
I have installed Windows 7 Ultimate 32 on my new Asus X553M and I have successfully installed all drivers except Intel HD graphics.
I am getting "The computer does not meet the minimum requirement"
I am downloading old and new drivers from Intel - does not work
I am downloading zipped and exe versions of driver - does not work
I am downloading http://www.intel.com/support/graphics/detect.htm Intel® Driver Update Utility. It detects the video but can not install the driver.
I am trying to update the driver through "Update driver" system option - does not work.
What am I doing wrong?
System Information
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: X553MA
BIOS: BIOS Date: 06/27/14 12:16:09 Ver: 05.06.05
Processor: Intel(R) Pentium(R) CPU N3530 @ 2.16GHz (4 CPUs), ~2.2GHz
Memory: 4096MB RAM
Available OS Memory: 2958MB RAM
Page File: 3287MB used, 2627MB available
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
Display Devices
Card name: Standard VGA Graphics Adapter
Manufacturer: (Standard display types)
Chip type: Intel(R) VLV Mobile/Desktop Graphics Chipset Accelerated VGA BIOS
DAC type: 8 bit
Device Key: Enum\PCI\VEN_8086&DEV_0F31&SUBSYS_161D1043&REV_0E
Display Memory: n/a
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 1366 x 768 (32 bit) (1Hz)
Monitor Name: Generic PnP Monitor
Monitor Model:
Monitor Id:
Native Mode:
Output Type:
Driver Name: vga
Driver File Version: 6.01.7600.16385 (Russian)
Driver Version: 6.1.7600.16385
DDI Version: unknown
Driver Model: unknown
Driver Attributes: Final Retail
Driver Date/Size: 7/14/2009 02:25:51, 10752 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4C71-11CF-F233-AD2BA0C2CB35}
Vendor ID: 0x8086
Device ID: 0x0F31
SubSys ID: 0x161D1043
Revision ID: 0x000E
Driver Strong Name: Unknown
Rank Of Driver: Unknown
Silvia_L_Intel1
AlexTol, sometimes it is necessary to install the graphics driver provided by the system manufacture, in your case from Asus.
Bear in mind that our drivers are generic and sometimes the OEM system does not allow the installation of them.
If you are still want to install our drivers, you may try forcing the installation by performing manual procedure, however I cannot assure you they are going to work as expected. See here for instructions: http://support.intel.com/support/graphics/sb/CS-022355.htm Graphics Drivers — Computer manufacturer graphics driver detected
Kevin_M_Intel
Hello AlexTol,
I noticed you opened another thread so we are going to continue from there.
This is the link:
/thread/57424 https://communities.intel.com/thread/57424
Kevin M
АТолм
Thank you Sylvia!
Thank you Kevin!
I tried it. But still does not work.
I do appreciate a lot your help. Will try to fight with windows to let the drivers work properly.
Silvia_L_Intel1
Alex were you able to resolve this issue?
АТолм
Hello Sylvia!
Thank you a lot for your advices. And you were right - there is no way to install 32 bit driver on that machine.
So finally I reinstalled the version to 64 bit and could install Intel drivers 64 bit version.
Silvia_L_Intel1
I am very glad to know you solved the problem successfully.
WQuin1
Help me please!
I' m using Lenovo B560, operating system Windows 7 Ultimate 64 bit.
whenever I try to install Intel(R) Hd GMA it always shows an https://www.google.co.in/search?client=firefox-b&q=win+7+Error+this+computer+does+not+meet+the+minimum+requirements+for+installing+the+software&spell=1&sa=X&ved=0ahUKEwjm8vXq3ffOAhVKsI8KHenoA2oQBQgaKAA Error this computer does not meet the minimum requirements for installing the software .
Not only that but when I try to Personalize my Display it always shows Troubleshoot problems with transparency and other Aero effects.
System Information
Time of this report: 9/5/2016, 01:38:24
Machine name: WONGLO-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_rtm.101119-1850)
Language: English (Regional Setting: English)
System Manufacturer: LENOVO
System Model: INVALID
BIOS: Ver 1.00PARTTBL
Processor: Intel(R) Pentium(R) CPU P6200 @ 2.13GHz (2 CPUs), ~2.1GHz
Memory: 3072MB RAM
Available OS Memory: 2868MB RAM
Page File: 687MB used, 5048MB available
Windows Dir: C:\Windows
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Chip type: Intel(R)Ironlake Mobile Graphics Chipset Accelerated VGA BIOS
DAC type: 8 bit
Device Key: Enum\PCI\VEN_8086&DEV_0046&SUBSYS_392017AA&REV_02
Display Memory: n/a
Shared Memory: n/a
Current Mode: 1024 x 768 (32 bit) (1Hz)
Monitor Model:
Monitor Id:
Native Mode:
Output Type:
Driver Name: vga
Driver File Version: 6.01.7600.16385 (English)
Driver Date/Size: 7/13/2009 16:38:47, 15360 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4306-11CF-1B34-9004ACC2CB35}
Vendor ID: 0x8086
Device ID: 0x0046
SubSys ID: 0x392017AA
Revision ID: 0x0002
Video Accel:
Deinterlace Caps: n/a
D3D9 Overlay: n/a
DXVA-HD: n/a
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_17AA6008&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6549 (English)
WHQL Logo'd: Yes
Date and Size: 1/10/2012 04:46:30, 4731112 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Microphone (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: GASIA
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0E8F, 0x0022
FF Driver: n/a
Device Name: GASIA
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: GASIA
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x3B3C
| Matching Device ID: usb\root_hub20
| Service: usbhub
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0020
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
+ HID Keyboard Device
| Matching Device ID: hid_device_system...
