23526 Discussions
abnormal status reported by rapid storage technology UEFI driver
CrusadOr
Hello!
Once I started my laptop and saw this:1.jpg
Then the BIOS automatically started and I saw this:2.jpg
Restart did not help, but once I plugged the charger out - it started normally.
It also appers now when I install some drivers and restart the laptop to apply changes.
The solution is always same: turn off the power, plug out the cable, start the laptop.
What might be the problem and the solution?
SSU logs are provided
Senkuchan
Valued Contributor II
This error message may suggest that there is an issue with your RAID configuration, your storage devices, or your Rapid Storage Technology driver. For this kind of concern, you can post your question to this link: https://community.intel.com/t5/Rapid-Storage-Technology/bd-p/rapid-storage-technology. Because this is the graphics forum, and you may get more relevant answers there.
You can also reach out to asus technical support since you are using an asus laptop for further assistance
Senkuchan
