22805 Discussions
about A770 go on
user6404
After I installed the A770, quasi-4K resolution to run Oka 2, the picture in the game is still relatively smooth, using the capture function in the intel control panel, the resolution is set to 2K when the captured video has obvious lag, is it a driver problem? How can I not reply to the post?
I can not reply to the post,so send a new massage.
video is here:
link:https://pan.baidu.com/s/1qD9Oa8eYUFx97y3VYnWsIw
Extract code:82or
Jean_Intel
Hello user6404,
We understand that you are having trouble replying to the thread. We are currently investigating an ongoing issue where some users are not available. While we investigate your problem internally, we will be contacting you through the e-mail address associated with your community profile, continuing with the support.
Best regards
Jean O.
Jean_Intel
Hello user6404,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello user6404,
Best regards.
Jean O.
