22723 Discussions
add Gigadevice Flash part into the VSCC table of Intel FITC/FPT tool
Dear Sir,
I am Jacky Long, Flash Marketing in Gigadevice. Our customer, Samsung electronic got one problem while trying to adopt Gigadevice SPI in their PC/NB design. To use descriptor mode in Montevina / Calpella, Samsung will be able to build BIOS through Intel FITC tool, But our flash didn't approved in this tool;
and to update, they have use the data file, fparts.txt through Intel FPT tool. Would you please advise us the solution? Thanks in advance!
Jacky Long
Allan_J_Intel1
I recommend consulting this information through an Intel Authorized Distributor, there you can work with a field application enginner.
A list of our distributors can be found below:
http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm
If you are outside the United States
http://premierlocator.intel.com/Default.aspx?CountryCPM=PL http://premierlocator.intel.com/Default.aspx?CountryCPM=PL
