23806 Discussions
arc b580
Talha2
I have a ryzen 7 5700g and a b550m plus motherboard in my system. 16 gb ram 3200 mhz. I tried to play 1080p in high graphics but it didn't work. I tried in low but it didn't work. There is a bottleneck in every game. I can't even enter these games.
RedCapsicum9
New Contributor II
based on your setup with the Intel Arc B580 GPU, Ryzen 7 5700G, and 16GB of RAM, it should be able to handle 1080p gaming. However, several factors could be causing the bottleneck.
Are you have the latest Intel Arc GPU drivers installed? Sometimes performance issues can be linked to outdated drivers, so updating to the latest version might help. Use a monitoring tool (like MSI Afterburner or HWMonitor) to check if your CPU or GPU is being fully utilized during gaming. If either is hitting 100% usage, it could indicate a bottleneck. Make sure that your system’s BIOS is up-to-date and that your system is running in performance mode to maximize your hardware’s capabilities. Although you’ve tried adjusting the graphics settings, some games may have specific optimizations or settings that could help. If possible, try lowering individual settings like shadows or texture details to see if there’s any improvement. and Temperature Check....
-bruce
