23850 Discussions
b50 pro issues
Kurt_ego
Brought a b50 pro to replace an A380 which was working perfectly. Now only get a display when before windows boots, and getting the attached error.
Have tried reseating the item
Checked resizable bar is on
installed standard and pro drivers - clean and none clean installed.
tried using device driver unintaller.
Can only remote in now.  (Windows server 2025)
JedG_Intel
Hello Kurt_ego,
Kindly share the information below for further investigation.
1. Which driver version/s have you used?
2. Have you had the chance to test using your older graphics card for isolation purposes?
3. Could you please provide the full model of your motherboard?
Best regards
Jed G.
Kurt_ego
1 drivers tried - Version: 32.0.101.8531 Version: 32.0.101.8314 - Q4.25.R2
2 Reverted to old card - Intel arc a380 working fine.
3 Motherboard - B650D4U-2L2T/BCM
Kurt
JedG_Intel
Hi Kurt_ego,
Thank you for sharing all this information with me. I will investigate this matter and I'll get back to you as soon as possible.
Best regards
Jed G.
Kurt_ego
JedG_Intel
Hi Kurt_ego,
I'm getting back in touch to provide you with an update following our investigation. Please try to follow the steps on How to Resolve Error Code 43 for Intel® Graphics. If the issue persists, kindly provide the information below.
 - Updated SSU report
 - What is the complete model of the power supply?
Best regards
Jed G.
JedG_Intel
Hello Kurt_ego,
I wanted to check if you had the chance to review the information I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
JedG_Intel
Hello Kurt_ego,
Jed G.
