May someone explain drivers version between 15.xx.xx.xx.xxxx 20.xx.xx.xx.xxxx and 21.xx.xx.xx.xxxx
am i right saying that 15 support wddm1.0 or 1.2 20 supports wddm 2.0 and 21 supports wddm 2.1 if yes question would be so what is the difference between them.
Check out: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005654.html Understanding The Intel® Graphics Driver Version Number
ok i have checked your link but it just confused me more. Could you decode 21.20.16.4526 vs 15.40.26.64.4474
21.20.16.4526 vs 15 40.26.64.4474
Intel® Iris.Windows®10.DX10.x up to 12.build number graphics driver version.Beta.64 bit.build version
Hope this helps.
Allan.
Thanks Allan, and helps and makes more questions as generic drivers made for Intel HD (skylake) doesnt work as 5001 version and drivers made for Intel iris works nearly fine on Intel HD (skylake). this version is the last version which works without problems at the moment 15 40.26.64.4474 on intel HD 530 with 6th gen cpu
Thank you for the feedback, I recommend you keep using driver 4474 and then, you can test future driver releases that will be available at https://downloadcenter.intel.com/ https://downloadcenter.intel.com/
Allan.
Hi Allan, thanks for reply and yes I'm back on 4474 version as I have no other option, yet
Keep on checking the download center website for future drivers.
Allan.
