23257 Discussions
can't install graphic driver on windows 7 64 bit system
pye
I bought a laptop (acer E5-575-57MJ) and I reinstall the system of windows7 64 bit. According to the seller, the graphic card is Intel HD graphics 620. But I can not install the driver for WIN7-64 ultimate system. I tried the driver utility, I also tried to download the driver from your website and install manually. It shows that "does not meet the minimum requirements". hardware ID is
PCI\VEN_8086&DEV_5916&REV_02
PCI\VEN_8086&CC_030000
PCI\VEN_8086
PCI\CC_030000&DT_9
PCI\CC_030000
PCI\CC_0300&DT_9
PCI\CC_0300
Stefan3D
Neither Intel nor Microsoft support this combination.
Check this thread: /thread/112384 "this computer does not meet the minium requirements for installing this software" g4560 gpu driver
However there are work-arounds at your own risk.
pye
What would be the workarounds? Would you elaborate?
Stefan3D
At first https://support.microsoft.com/en-us/instantanswers/e6bbddb0-9db4-4d88-9063-42c52c79a96e/create-a-system-restore-point create a system restore point
Modify INF for Intel driver as discussed here:
And https://www.techpowerup.com/232527/user-patch-unlocks-windows-7-and-8-1-updates-for-core-kaby-lake-and-ryzen User Patch Unlocks Windows 7 and 8.1 Updates for Core "Kaby Lake"
Hello yeparticle,
I understand you are trying to install Windows 7* graphics driver for Intel HD Graphics 630.
Let me apologize for any inconvenience this issue may be causing to you.
What happens is that Intel HD Graphics 620 supports Windows 10* so there are no drivers available for older operating systems including Windows 7*. This link will provide more information about supported operating systems http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html
The best option would be reinstalling the operating system that came with the computer so you can have drivers for it. You can reinstall the operating system using the Acer* recovery discs. This link will show you how to get them https://us-store.acer.com/erecovery/rcd/ https://us-store.acer.com/erecovery/rcd/
Fred
Hello yeparticle,
I was wondering if you still need assistance regarding the graphics driver you are trying to install. In case you still need assistance just let me know.
Fred
pye
I already re-installed my system. Windows 10 is not that bad eventually.
Hello yeparticle,
Thanks for letting me know that. Do not hesitate to contact us back if you have any other inquiry.
Fred
