23801 Discussions
can't re-install Driver & support assistant.
DPADM1
when i tried to re-install Driver and supprt assistant, after ruuning the installation file, it always shows " Are you sure you want to remove this program". I tried completely removing the previous program but still showing the same. Please help.
LeonWaksman
DPADM1
Tried it many times. Still asking to uninstall the program when i run the installation file.
LeonWaksman
Clear also the cache (browsing history) in your Internet Browsers.
Leon
DPADM1
I cleared the cache and also disabled firewall. But still the same.
Alberto_R_Intel
DPADM1, Thank you for posting in the Intel® Communities Support.
Just to let you know, if there is a problem installing or re-installing the Intel® Driver and Support Assistant the issue might be due to the following reasons:
  • You have an older component.
  • Your component is discontinued or is not supported.
  • You have a component not produced by Intel.
  • You have a customized driver pre-installed by the computer manufacturer.
  • The component is not in Intel's database.
In this case, we recommend to manually install the drivers provided by the manufacturer of the computer, since those drivers were customized by them work with your specific platform.
To install the proper drivers for your system, please visit the following link, choose the operating system and you will be able to see all the drivers for your computer:
https://www.asus.com/us/Laptops/ASUS-VivoBook-S15-S530UN/HelpDesk_Download/
Please let us know the results of trying to manually install the drivers.
Alberto R.
Under Contract to Intel Corporation
Alberto_R_Intel
DPADM1, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R.
Alberto_R_Intel
DPADM1, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question.
Alberto R.
