23808 Discussions
chipset update failed
LPari1
I am using the Intel driver utility to update the chipset on my windows 7 hp pavilion notebook. I used the auto detect to find the driver and every time I try to install the update it fails. It does not give me a reason. I have attached the debug file
Kevin_M_Intel
The driver you are installing is a very basic driver from our side. The reason why you are having problems to install it is that your computer requires a special driver that will work just fine in your system.
My best recommendation is to install the chipset driver from the Computer Manufacture since it contains special configurations or limitations for your computer.
Kevin m
