code 8
mani0733
if i download the graphic control panel and i open it it says driver not found code 8
n_scott_pearson
The Intel Graphics Control Panel was EOL'ed a couple of years ago. I very much doubt that it can just be copied onto a machine and the infrastructure to support it will be present and continue to work. The replacement is the Intel Graphics Command Center. You must use that app. for graphics configuration.
I too liked the functionality of the Control Panel and am still sore at Intel for dropping so many features when they developed the replacement. Regardless, what's done is done. You cannot use the Control Panel with the DCH-architected drivers - and you can blame Microsoft for forcing that change.
