23484 Discussions
compatibility of i5 12400 and arc b580.
Hasan_
I currently use an i5 12400 paired with an arc a750. I am happy with it but now i want to upgrade my gpu to b580. Can i upgrade without facing the overhead issue? I game at 1080p. My system has is a ddr4 3200mhz system with 32 gb ram and a gen 3 nvme ssd. Pls help.
RandyT_Intel
Hi @Hasan_,
Upgrading your GPU from an Intel Arc A750 to an Intel Arc B580 should generally provide a performance boost, especially for gaming at 1080p. However, there are a few considerations to keep in mind to ensure you don't face any overhead issues.
Intel Core i5-12400 is a capable processor, especially for 1080p gaming. It should be able to handle the B580 without significant bottlenecking. However, if you play CPU-intensive games or use applications that require heavy CPU processing, you might experience some limitations. For most gaming scenarios at 1080p, your CPU should be sufficient. Ensure your power supply unit (PSU) can handle the increased power requirements of the B580. Check the recommended wattage for the B580 and compare it to your current PSU's capacity. If necessary, upgrade your PSU to avoid power-related issues. Make sure to update your GPU drivers to the latest version to ensure optimal performance and compatibility with the B580.
To summarize, your system should be able to handle the upgrade without significant overhead issues, especially for 1080p gaming. Just ensure that your PSU, cooling, and drivers are up to date to support the new GPU effectively.
You may visit this article: Intel® Arc™ Graphics – Desktop Quick Start Guide
Let me know if you need more information.
Randy T.
RandyT_Intel
Hi @Hasan,
Randy T.
RandyT_Intel
Hi @Hasan,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Randy T.
