23762 Discussions
dedicated video memory 0
kmorr6
hello I have a new model laptop
*GPU Intel HD Graphics 505
8gb ram ddr4 2222 ghz
Latest dedicated memory drivers installed correctly
the problem is with the intel graphics 505 i find dedicated memory of video 0 zero so every time I want to play an old game that more than meets the requirements does not leave me for lack video.
I tried to fix it on my own but in google there is no information on how to fix that error on this integrated graphics.
Thank you iwould appreciate telling me how to fix this small but annoying problem.
David_V_Intel
Hello kmorr6,
Thank you for posting on the Intel ® communities.
There is no way to preset the dedicated video memory to a specific value, you can only limit the maximum memory that it can take.
This option is usually available in BIOS. The settings users can modify are 128 MB, 256 MB and maximum DVMT. Setting other values depends on the motherboard manufacturer and the amount of RAM installed on the computer.
I would recommend contacting the system manufacturer or motherboard manufacturer so they can provide options for you to change the dedicated video memory if possible.
David V
A Contingent Worker at Intel
David_V_Intel
Hello kmorr6,
Were you able to check my previous post?
Let me know if you need more assistance.
David V
kmorr6
hello
I could not enter the bios until I succeeded (today) :-D. I increase the video increased to 512 mb (see image)
"and the mouse disappears from the screen". it only gets fixed by reversing the changes
why does that happen?
"previously" I increased the vram through the local regedit machine, created a dedicated key segmensize (Do I have to reverse this and do it from the "only bios")?.
some other option of the bios that you recommend me to have better graphic performance "fps"
really very grateful in advance
David_V_Intel
Hello kmorr6,
Thank you for your response.
You can have more information about video memory in the link below:
https://www.intel.com/content/www/us/en/support/articles/000020962/graphics-drivers.html
Since this option is managed in the BIOS, the system manufacturer should be able to assist you with how to set it up without having the issues you mention.
David V
