22940 Discussions
dg33bu GMA 3100 code 43 windows 7 unable to use aero
Hello, I'm having problem trying to use aero on windows 7, i have a dg33bu motherboard, gma 3100 and i can't get it to work.
I downloaded the last version drivers for windows 7 64bits, I installed them but I get code 43 (Windows has stopped this device because it has reported problems), so I wanted to know if it is some kind of driver issue, or the gma is not compatible with windows 7, I've been looking everywhere for an answer and couldn't find anything so far, I would really appreciate some help.
Thanks in advance
I have same problem with windows 7, my motherboard is dg33fb
Your chipset does support Windows* Aero. The driver posted in our web site has been tested and know to work, you may have a driver corruption or an operating system issue.
At this time my suggestions are to update your motherboard BIOS
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+3+Series+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+DG33BU http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+3+Series+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+DG33BU
Try a fresh install of the operating system and remember to install the chipset driver first, after that install the latest video driver.
You can use this utility:
http://www.intel.com/support/graphics/detect.htm http://www.intel.com/support/graphics/detect.htm
PV.
Thanks for reply.
I already done all those things what you mentioned .
motherboard is DGFB33 and os WINDOWS 7 HOME PREMIUM 64 BIT
i followed steps written below
update bios from DPP3510J.86A.0572.EB.
reinstall windows home premium 64 bit
install driver for chipset from INF_allOS_9.1.1.1025_PV.
install driver for graphics from GFX_Win7_64_15.12.75.4.64.1930_PV_Intel.
but still same problem is coming.
In display adapter yellow exclamation mark in intel(R) G33/G31 EXPRESS CHIPSET
actually i already receive message that windows has successfully update your driver software.
one more thing sound only comes in my right headphone speaker i checked for balance ,proper jack connection but same problem still there.
in sound,video and game controller option under device manager
two items are listed there
1. High Defination Audio Device
2. Realtek high defination audio
I have no issue with windows xp .
hi didnt get any update
