22765 Discussions
display and videos flikring
Malay
after the intel graphic command center has replaced intel graphics control panel, suddenly my desktop is started flikring and i am unable  to play/see any videos only audio is hearable but no video is visual....
enclosing two samples
kindly help
AndrewG_Intel
Hello @Malay
We understand you have opened an internal Web Ticket Support with us and we will continue to help you through that channel now. We will therefore close this community case. Thank you.
Andrew G.
Malay
i am not receiving any support from intel support...
please help
Malay
Malay
someone please help me.... i am uable to work on my laptop
n_scott_pearson
Please download and run the Intel System Support Utility for Windows. Select *all* data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog (below the edit box for the body of your response post), upload and attach this text file to the response post.
Malay
Dear Scott
Thanks for your efforts.
Malay
