23854 Discussions
display
Viceroy46
display has yellow cast
AlHill
Lots more information needed.
[W10 is this generation's XP]
DhannielM_Intel
Hello Viceroy46,
Thank you for posting in the community. I agree with @AlHill that the post lacks sufficient information to address the issue. Let's start by identifying the device you're using. Are you on a desktop or a laptop? If it's a laptop, could you provide the exact model? Additionally, could you share a screenshot of the issue on your display? To gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. How to get the Intel® System Support Utility Logs on Windows
Dhanniel M.
DhannielM_Intel
Hello Viceroy46,
I'm following up to see if you could provide additional information or respond to the questions I posted earlier.
Dhanniel M.
DhannielM_Intel
Hello Viceroy46,
Since I haven't received a response, I will proceed to close this inquiry. Should you require additional assistance, please feel free to submit a new question, as this thread will no longer be actively monitored.
Dhanniel M.
