22733 Discussions
does anyone find it dissatisfying that Intel Turbo Memory drivers don't work with newer Rapid Storage Technology drivers?
Considering I have a laptop that would probably like more recent drivers than year old ones why wouldn't Intel make drivers for Turbo Memory that work with newer storage manager drivers? If I install newer RST drivers ITM dashboard craps out.
Thanks for not responding, Intel
Same here, thanks for no answer
DSilv11
Valued Contributor III
Perhaps if you need a responce from Intel support, you should try the Intel support page rathar than the User community pages? http://www.intel.com/support/feedback.htm?iid=subhdr+res_contact http://www.intel.com/support/feedback.htm?iid=subhdr+res_contact
Ditto. I recently bought 2 of these cards to install into workstations. Neither card work correctly and also crash the nVidia driver for the graphics cards as well. This is also running the 8/2009 (Latest) driver. The only way I can get these systems running again is to roll back Win7 64Bit.
The installer memtioned the warning regarding the storage driver being newer, but following the instructions given statedto click yes and continue the installation.
@Doc Silvercreek - The support page is fine and dandy, but there doesn't seem to be a way to use their system for this hardware as it does not appear anywhere in the support e-mail system. Intel support should be actively checking these forums regardless. If they provide forums, they should expect to answer questions on them as many other companies do.
