23599 Discussions
does not meet minimum requirements error when installing Intel HD graphic 530
mrame
I Recently bought an core i5-6400 (2.7 GHz) cpu, asus z170-k motherboard and gigabyte gtx 970 graphic.
I downloaded "win64_15407.4279.exe" for Intel HD graphic 530 from: https://downloadcenter.intel.com/download/25274/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-7-8-1-10 Download Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows® 7, 8.1, & 10
When I try to install this driver for win 8.1 64-bit, the "this computer does not meet minimum requirements" error occurred.
I have not any output from VGA DVI and HDMI sockets of motherboard but outputs of gtx 970 graphic are ok.
although I tried to install "Intel Graphics Accelerator Driver V10.18.15.4274 for Windows Win7 64bit & Win8.1 64bit & Win10 64bit---(WHQL)." from https://www.asus.com/Motherboards/Z170-K/HelpDesk_Download/ https://www.asus.com/Motherboards/Z170-K/HelpDesk_Download/, same error again!
Please help! I need motherboard vga output
Filip_Z_Intel
If You have a Windows 10 then please try to use Windows Update - does it help?
Otherwise please try these steps:
mrame
Upgrading to win 10 64bit didn't helpful. same error: "This computer does not meet minimum requirements"
There isn't "Intel HD Graphics" in "Display adapters" section of device manager!!! only Nvidia GTX 970 is shown!
The Log file was attached:
https://www.mediafire.com/?ms84xatsqy1zyqu https://www.mediafire.com/?ms84xatsqy1zyqu
gbhj
the log says it did not find your Intel GPU in the driver setup script
if a driver has never being installed it will not know the name try looking in other device or any other device that is listed in the display driver section
try the zip version of the Intel driver
mrame
Enabling CPU graphic from BIOS, solved the problem
Amy_C_Intel
Hello gharibe6856,
I am glad to hear that you were able to resolve your issue. Your feedback is important to us and I thank you for taking the time to communicate this matter.
Amy.
