23269 Discussions
Do I need the intel hd graphics control panel service to run?
LMoso1
It seems like the intel hd graphics control panel service just displays the control panel icon in the system tray.
If I disable this service, will it do anything bad?
Also, if I have an nvidia card, then can I also disable the service for that control panel icon too?
I contacted nvidia and they said if the nvvsvc.exe service was diasbled then it would make the control panel stop working. But it just seems you can access the control panel for nvidia with nvcplui.exe
So with both of these services, are they necessary for the control panels for both cards to work? Or can I disable them without having any consequences?
Will my video cards work properly if I disable them?
Ricardo_G_Intel1
In this case if you are ussing a dedicated graphic card (Nvidia) the system ellectronically disables the Intel® graphics from the processor. Depends form your system you can disable the onboard graphics ( Intel®) form BIOS or from the startup options you can desable it to start.
LMoso1
what? can you please explain this is proper grammar because i don't understand anything you said
gbhj
there is a registry setting that can be used to disable the CUI (Intel control panel) search for "CUINotRequired" in regedit
you can also improve the effectiveness of both GPU's by setting "SOFTWARE\Intel\KMD/EnableControlPrimaryTLBUtilization" to 0x1
LMoso1
why do i need to disable it? why don't I just disable the service? what does disabling it do rather than disabling the service.
and there is no registry entry for what you referenced in my registry...
gbhj
both will work however the service is needed for settings to be applied to the GPU
you have to add items that are not present in the registry like
LMoso1
so both of these cards will work even if the control panel services are disabled for both the nvidia and the intel?
what does adding this registry key do?
and where exactly do i add this key? local machine or current user or where?
Ricardo_G_Intel1
Answering to your question, the computer is using the Nvidia Graphics, what you can do is remove the Intel® icon from the system tray.
