23823 Discussions
driver de audio
carloshenrique77
Placa Mae TGT H81 DDR3 Socket LGA1150 Chipset Intel H81 a 4 meses usando adaptador de som pois o headset noa funciona no plug do pc necessito de ajuda... nao acho driver pra baixar meu win eo 10 home
AlHill
What motherboard model number?
What audio driver?
Have you check with your system/motherboard manufacturer website for the driver specific to your motherboard?
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
carloshenrique77
Placa Mae TGT H81 DDR3 Socket LGA1150 Chipset Intel H81 modelo da placa mae e esse. mn qualquer driver serve so pra funciona. não acho o site do fabricante, sou novo sei pouco sobre essas parada. eu baxei oq vc pediu mais nao consigo salvar de jeito nenhum o arquivo
Alberto_R_Intel
carloshenrique77, Thank you for posting in the Intel® Communities Support.
Apenas para informar, oferecemos suporte apenas em inglês e, atualmente, estamos usando uma ferramenta de tradução.
In order for us to be able to further asist you with this matter, please attach the SSU report so we can verify further details about the components in your platform, check all the options in the report including the one that says "3rd party software logs":
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Based on the picture you shared, you need to select "Save" and then attach the file to this thread.
Albert R.
Alberto_R_Intel
Hello carloshenrique77, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello carloshenrique77, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
