23102 Discussions
driver grafico intel adatto a toshiba satellite pro C850 1CU
nblan
non riesco ad installare il driver video intel sul mio pc toshiba satellite pro C850 1CU, driver forniti dal sito toshiba per win 7 non funzionano o non si installano, vorrei provare a scaricare i driver direttamente dal sito intel, come posso fare?
EstebanA_C_Intel
Hello, nunzio:
Thank you for contacting the Intel Communities.
After using the translate feature, I was able to find out you are having issues while installing the graphics driver in your system.
While using OEM systems like yours, the recommendation is to download and install the drivers from your computer's manufacturer website.
This is to avoid loosing any special features or settings while using the generic drivers from Intel®.
Here you can find the drivers for the Toshiba SATELLITE PRO C850: http://www.mytoshiba.com.au/support/computers/satellite/pro/c850/pskc9a-00t019/download?os=25 Support :: Toshiba :: Computers, Laptops/Notebooks, Tablets, Televisions, DVD and Blu-Ray Players, Camcorders, Storage, …
Please do test them in your system.
In case you are still not able to install them, here you can find the generic drivers from our end:
Windows 7* 32-bit: https://downloadcenter.intel.com/download/24970/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-32bit?product=81500 Download Intel® HD Graphics Driver for Windows* 7/8/8.1-32bit
Windows 7* 64-bit: https://downloadcenter.intel.com/download/24971/Intel-HD-Graphics-Driver-for-Windows-7-8-64-bit?product=81500 Download Intel® HD Graphics Driver for Windows* 7/8-64-bit
You could also test this method to install the drivers if the you encounter with issues while using the executable file:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html How to Manually Install a Driver in Microsoft Windows 7* for Graphics...
If you require any further information or support, feel free to contact us back.
Esteban C
EstebanA_C_Intel
Hello, nunzio:
Esteban C
nblan
thank you!
I solved the problem by using the link intel .
drivers Toshiba links do not work properly.
Good job!
EstebanA_C_Intel
Hello, nunzio:
Thank you for your answer.
I am glad to hear that you were able to fix this issue.
If you require any further information or support, do not hesitate to visit the Intel Communities again.
Esteban C
