23525 Discussions
drivers for intel hd graphics intel core i5 m560 for windows 10?
BPort1
will drivers for the Intel HD graphics core i5 M560 for Windows 10? that those who are using the version 8.15.10.2900 of the date November 26, 2012 for Windows 7 and do not work well on Windows 10, they are very old
ZKost1
I have the same problem. This happens when you set the display to be turned off at idle and then to include display driver gives error. Intel HD graphics core i5 M480M
BPort1
I had the same problem but solved by upgrading to the latest version of Windows 10 Build 10240. The problem today is the low yield of the Blast plotted by the controller is very, very old.
DHera1
Same CPU...
Brightness stuck at low and the setting does not work
Any tip ?
BPort1
What is your PC? Brand and model
DHera1
Sony VAIO VPCS13C5E with I5 m560 + HD Graphics.
DHera1
My brightness control works only with standard Microsoft VGA Driver.
Allan_J_Intel1
Please bear in mind you have an Intel® HD Graphics first generation graphics. If you check the list of supported operating system linked below, you will notice that Windows 10 is not available.
http://www.intel.com/support/graphics/sb/CS-034343.htm Graphics Drivers — Supported Operating Systems
Allan.
FAsd
So if this generation of proccessors it's not compatible, why the heck did you guys allowed the Windows 10 update?? it's just stupid. Sorry guys but this is stupid. Never buying a intel thing again.
Allan_J_Intel1
If you owned Windows operating system version previously, Microsoft itself provided this update, this is independent of the hardware of your computer.
Allan.
AndrePS
Thank you for the welcome
AlHill
Responding to a 6-year old thread?
There is no driver for your graphics for Windows 10, except the Microsoft generic driver,
It is time for you to upgrade to a new system.
