23832 Discussions
drivers
PotatoGod
I am trying to update my intel driver but the driver will not download it just stays on "downloading 0%" (i am on a 2019 hp laptop)
DeividA_Intel
Hello PotatoGod,
Thanks for the information. Before we continue further, I would like to confirm the following:
1. Check with Hp since you are having issues also with the drivers. Also, try to confirm if your laptop is compatible with Windows 11.
2. Use the Intel® Driver & Support Assistant, this tool is meant for Intel products like NUCs, however, test if this can help install the driver:
3. Have you performed a clean installation of the driver?
Let me know if the issue persists.
Deivid A.
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
PotatoGod
Ok
DeividA_Intel
Hello PotatoGod,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your
1. Are you trying to install the driver using the Intel® Driver & Support Assistant (Intel® DSA)?
2. Are you trying to manually install the driver?
3. Does this issue happen with Intel or HP drivers?
4. Did the laptop come with Windows 11 preinstalled?
5. Have you reported this issue to HP?
Deivid A.
PotatoGod
1 I am clicking the download button on the website
2 When i try with hp the website doesnt load
2 my issue is on intels website
3 it is a 2019 hp pavillion that came with windows 10 home preinstalled and i updated to windows 11
4 no i have not reported it to hp
DeividA_Intel
Hello PotatoGod,
Deivid A.
PotatoGod
The Link For clean installation worked
DeividA_Intel
Hello PotatoGod,
I reviewed your post, please let me know if the issue was resolved, if not, do not hesitate, just reply back.
Deivid A.
DeividA_Intel
Hello PotatoGod,
I am glad to know that the issue was fixed by performing a clean installation of the Intel drivers. I will proceed to close this thread
Bear in mind that you can open a new thread in case you need further support or if you encounter any issues with Intel products.
Deivid A.
