23850 Discussions
error code 28 Intel Drivers
AxelFox
I have an Legion Pro 5 16IAX10H and I installed Windows 10 on it.
Now I am having issues with Intel drivers. I tried Lenovo support site to find the drivers and Intel Driver & support Assistant. I don't know where to find the drivers or if it's just incompatible with Windows 10.
Ramgound_Intel
Thanks for reaching out. We understand that you’re having difficulties finding the correct Intel drivers after installing Windows 10 on your Lenovo Legion Pro 5 16IAX10H.
For this laptop, the available Lenovo OEM drivers appear to be intended for Windows 11 64-bit. Because this is an OEM system, we recommend using the drivers provided by Lenovo for your specific model rather than forcing generic Intel drivers.
If Windows 10 drivers are not available on the Lenovo support page for your system, this may indicate that Windows 10 is not a supported operating system for this configuration. In that case, we recommend using Windows 11 to ensure the appropriate drivers are available and supported.
If you can share a screenshot of the driver issue or the Intel device showing the problem in Device Manager, we can take a closer look and guide you further.
Ramgound_Intel
AxelFox
It turns out you are correct on there was no supported drivers for Windows 10. I end up upgrading to Windows 11 and everything works now.
Thanks for your help.
Ramgound_Intel
That's great news! I'm glad to hear that upgrading to Windows 11 resolved the issue and that everything is working properly now.
Thank you for confirming the outcome and for working with us throughout the troubleshooting process.
If you have a moment, could you please mark the solution as accepted in the community thread? This helps other users experiencing similar issues find the resolution more easily.
If you need any assistance in the future, please don't hesitate to reach out.
Thanks again, and have a great day! 😊
garagedoor
The main thing to check is whether the Legion Pro 5 16IAX10H officially supports Windows 10. If Lenovo doesn't provide Windows 10 drivers for that specific model, some Intel chipset, MEI, graphics, or power-management drivers may not install correctly even if Windows 10 itself runs.
I’d check the exact hardware IDs in Device Manager and compare them with the available Lenovo Windows 10 drivers. If you share a screenshot of the devices showing the driver errors, it should be possible to identify which Intel drivers are missing and whether there’s a compatible version available.
