23722 Discussions
fps drop with i7
silardo
im having some fps drop while gaming (waframe, divinity OS 2, destiny 2...)
it doesn`t metter if its in low graphics or high. for example, playing destiny 2 in high specs, sometimes in the battle the fps lock in 60, and then suddenly drops to 25 or something like it. It happens when paying in low specs too.
It happens in almost every game with some nice graphics.
problem is my CPU not in high process, can someone tell me how to max the process ?
you can check all info about my system on this pdf:
https://dlandroid.com/wp-content/uploads/2021/09/Laptop-info.pdf
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Windows 11 is the new Vista]
