23767 Discussions
glReadPixels Fails on Intel HD 4600
John_H_4
I have an Intel HD 4600 Notebook with the latest Drivers (10.18.10.3960 29/9/2014) running on Windows 8.1 64bit.
I am writing an OpenGL application which needs to read pixels from a Framebuffer.  The Intel Driver reports an OpenGL error 1282 and fails to read.  I have tried different formats (GL_FLOAT and GL_UNSIGNED_BYTE etc), but all fail.  I believe the code is OK as the same code works fine on NVIDEA and AMD hardware.
NOTE The glReadPixels works OK if I am reading from the GL_BACK buffer and only fails if I attempt to read from another buffer.
Is this a Driver Bug or am I doing something wrong??  Any assistance to get this working appreciated.
Some code below...
Setup the Frame Buffer
   // Create the FBO
      glGenFramebuffers(1, @fFBOHandle);
      glBindFramebuffer(GL_FRAMEBUFFER, fFBOHandle);
  // Create the texture object for the primitive information buffer
      glGenRenderBuffers(fColBufSize, @fColorBuffer[0]);
      for I := 0 to fColBufSize-1 do
      Begin
        glBindRenderBuffer(GL_RENDERBUFFER, fColorBuffer);
        glRenderBufferStorage( GL_RENDERBUFFER, GL_RGBA32F,  SizeX, SizeY );
        glFramebufferRenderBuffer (GL_DRAW_FRAMEBUFFER, GL_COLOR_ATTACHMENT0 + I, GL_RENDERBUFFER, fColorBuffer );
        fBuffer :=  GL_COLOR_ATTACHMENT0 + I;
      end;
  // depth
      if fIncDepthBuffer then
      Begin
        glGenRenderBuffers(1, @fDepthBuff);
        glBindRenderBuffer(GL_RENDERBUFFER, fDepthBuff);
        glRenderBufferStorage( GL_RENDERBUFFER, GL_DEPTH_COMPONENT24,  SizeX, SizeY );
        glFramebufferRenderBuffer(GL_DRAW_FRAMEBUFFER, GL_DEPTH_ATTACHMENT, GL_RENDERBUFFER, fDepthBuff);
      end;
      glDrawBuffers(fColBufSize, @fBuffer[0]);
  // Verify that the FBO is correct
      aStatus := glCheckFramebufferStatus(GL_FRAMEBUFFER);
      CheckForGLErrors('Float Buffer Set Size');
  // Restore the default framebuffer
      glReadBuffer(GL_NONE);    //for older hardware
      glBindRenderbuffer(GL_RENDERBUFFER, 0);
      glBindFramebuffer(GL_FRAMEBUFFER, 0);
Read the Pixels from the FramBuffer.  The PixelID is a local array and X,Y is the mouse location.
      glBindFramebuffer(GL_READ_FRAMEBUFFER, fFBOHandle);
      glReadBuffer(GL_COLOR_ATTACHMENT0);
      glReadPixels(x, y, 1, 1, GL_RGBA,   GL_FLOAT, @PixelID[0]);
John_H_4
I have re-posted with the correct layout see glPixelReads fails on FrameBuffer
