23768 Discussions
glReadPixels fails on RenderBuffer
John_H_4
This is a re-post using the requested layout
System Setup Information:
System Used: Dell Alienware 17
CPU SKU: Intel(R) Core(TM) i7-4800MQ CPU @ 2.70GHz
GPU SKU: HD4600
Processor Line:
System BIOS Version: Alienware A01
CMOS settings:
Graphics Driver Version: 10.18.10.3960
GOP/VBIOS Version:
Operating System: Windows 8.1 64bit
OS Version: 6.2.9200
API: OpenGL
Occurs on non-Intel GPUs?: NO
Steps to Reproduce:
Setup the Frame Buffer
   // Create the FBO
      glGenFramebuffers(1, @fFBOHandle);
      glBindFramebuffer(GL_FRAMEBUFFER, fFBOHandle);
  // Create the texture object for the primitive information buffer
      glGenRenderBuffers(fColBufSize, @fColorBuffer[0]);
      for I := 0 to fColBufSize-1 do
      Begin
        glBindRenderBuffer(GL_RENDERBUFFER, fColorBuffer);
        glRenderBufferStorage( GL_RENDERBUFFER, GL_RGBA32F,  SizeX, SizeY );
        glFramebufferRenderBuffer (GL_DRAW_FRAMEBUFFER, GL_COLOR_ATTACHMENT0 + I, GL_RENDERBUFFER, fColorBuffer );
        fBuffer :=  GL_COLOR_ATTACHMENT0 + I;
      end;
  // depth
      if fIncDepthBuffer then
      Begin
        glGenRenderBuffers(1, @fDepthBuff);
        glBindRenderBuffer(GL_RENDERBUFFER, fDepthBuff);
        glRenderBufferStorage( GL_RENDERBUFFER, GL_DEPTH_COMPONENT24,  SizeX, SizeY );
        glFramebufferRenderBuffer(GL_DRAW_FRAMEBUFFER, GL_DEPTH_ATTACHMENT, GL_RENDERBUFFER, fDepthBuff);
      end;
       glDrawBuffers(fColBufSize, @fBuffer[0]);
 // Verify that the FBO is correct
      aStatus := glCheckFramebufferStatus(GL_FRAMEBUFFER);
      CheckForGLErrors('Float Buffer Set Size');
  // Restore the default framebuffer
      glReadBuffer(GL_NONE);    //for older hardware
      glBindRenderbuffer(GL_RENDERBUFFER, 0);
      glBindFramebuffer(GL_FRAMEBUFFER, 0);
Read the Pixels from the FramBuffer.  The PixelID is a local array and X,Y is the mouse location.
      glBindFramebuffer(GL_READ_FRAMEBUFFER, fFBOHandle);
      glReadBuffer(GL_COLOR_ATTACHMENT0);
      glReadPixels(x, y, 1, 1, GL_RGBA,   GL_FLOAT, @PixelID[0]);
Expected Results:
glReadPixels should return data from the current glReadBuffer without an error.
Actual Results:
The glReadPixels call generates and OpenGL debug message (Source: OpenGL ; Type : Error ; Severity : HIGH ; Message : Error has been generated. GL error GL_INVALID_OPERATION) and an OpenGL Error 1282 is on the OpenGL error stack.
No errors exist on the OpenGLK Error stack before the glReadPixels.
Additional Information:
DXDiag Report
Time of this report: 11/26/2014, 06:49:50
       Machine name: DBS040
   Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_r3.140827-1500)
           Language: English (Regional Setting: English)
System Manufacturer: Alienware
       System Model: Alienware 17
               BIOS: A01
          Processor: Intel(R) Core(TM) i7-4800MQ CPU @ 2.70GHz (8 CPUs), ~2.7GHz
             Memory: 32768MB RAM
Available OS Memory: 32486MB RAM
          Page File: 10880MB used, 54372MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: 96 DPI (100 percent)
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.03.9600.16384 64bit Unicode
Display Devices
          Card name: Intel(R) HD Graphics 4600
       Manufacturer: Intel Corporation
          Chip type: Intel(R) HD Graphics Family
           DAC type: Internal
        Device Type: Full Device
         Device Key: Enum\PCI\VEN_8086&DEV_0416&SUBSYS_05AA1028&REV_06
     Display Memory: 1792 MB
   Dedicated Memory: 32 MB
      Shared Memory: 1760 MB
       Current Mode: 1920 x 1080 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: unknown
         Monitor Id: LGD02DA
        Native Mode: 1920 x 1080(p) (60.012Hz)
        Output Type: Internal
        Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3960 (English)
        DDI Version: 11.1
     Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
       Driver Model: WDDM 1.3
Graphics Preemption: Primitive
 Compute Preemption: Thread group
           Miracast: Supported
Hybrid Graphics GPU: Integrated
     Power P-states: Not Supported
  Driver Attributes: Final Retail
   Driver Date/Size: 10/3/2014 17:36:50, 24185400 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp:
  Device Identifier: {D7B78E66-4756-11CF-E362-A725BBC2C435}
          Vendor ID: 0x8086
          Device ID: 0x0416
          SubSys ID: 0x05AA1028
        Revision ID: 0x0006
 Driver Strong Name: oem27.inf:5f63e534dd929195:iHSWM_w81:10.18.10.3960:pci\ven_8086&dev_0416
     Rank Of Driver: 00DA2001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
        DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeWMV9_IDCT  DXVA2_ModeVC1_IDCT  DXVA2_ModeH264_VLD_NoFGT
   Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
       D3D9 Overlay: Supported
            DXVA-HD: Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
Michael_C_Intel2
Thanks John. I have created an internal ticket and am talking with our OpenGL driver developers. I will update you once they have had a chance to look at the issue
John_H_4
Further to this problem, I have found that when I try and rebuild the buffers after a WMSize message (ie window size change) the problem will get worse.
The 1282 error is generated continuously for every glReadPixels.
Any feedback on this?  Would you like a copy of the executable?
