23800 Discussions
glTextureView() and GL_STENCIL_INDEX bug on Intel UHD620
Tarquiscani__Andrea
System Setup Information:
System Used: HP ENVY Laptop 17-ae142ng
CPU SKU: i7-8550U CPU
GPU SKU: Intel UHD Graphics 620
Processor Line: Kaby Lake R
System BIOS Version: Insyde F.28, 29/04/2019
CMOS settings:
Graphics Driver Version: 25.20.100.6519
GOP/VBIOS Version:
Operating System: Microsoft Windows 10 Home 64bit
OS Version: 10.0.18362 Build 18362
API: OpenGL 4.3
Occurs on non-Intel GPUs?: No
Steps to Reproduce:
I'm using a texture view to ease the access to the stencil index of a depth-stencil texture. It works perfectly fine on the dedicated nVidia GPU, but doesn't work on the integrated Intel GPU. I know that the stencil values are there in the depth-stencil texture because I checked them via glGetTexImage(). But when I access these values in the shader (by the texture view) I get only zeroes.
I did some tests. If I set the parameter GL_DEPTH_STENCIL_TEXTURE_MODE to GL_STENCIL_INDEX directly on the depth-stencil texture, avoiding the use of the texture view, then it works fine. If I use the texture view to retrieve the depth component (leaving GL_DEPTH_STENCIL_TEXTURE_MODE to the default value, i.e. GL_DEPTH_COMPONENT), then the texture view works fine. It seems that only the combination of both produces an error.
The full minimal code is pretty long, so I removed certain parts, but I can provide the full code if needed.
filter.fragmentshader
#version 430 core
out vec4 fs_frag_color;
in vec2 vs_tex_coords;
layout (binding = 0) uniform usampler2D u_stencil_tex;
void main()
    uint draw_count = texture(u_stencil_tex, vs_tex_coords).r;
    // Show stencil buffer
    if(draw_count == 1)
        fs_frag_color = vec4(0, 1, 0, 1);
    else if(draw_count > 1 && draw_count <= 10)
        float orange_shade = float(draw_count + 5) / 15.0;
        fs_frag_color = vec4(orange_shade, orange_shade, 0 ,1);
    else if(draw_count > 10 && draw_count <= 50)
        float red_shade = float(draw_count + 5) / 55.0;
        fs_frag_color = vec4(red_shade, 0, 0, 1);
    else
        fs_frag_color = vec4(0, 0, 0, 1);
main.cpp
int main(void)
    //Initialize GLFW and open a window with a 4.3 OpenGL context
    glEnable(GL_DEBUG_OUTPUT);
    glEnable(GL_DEBUG_OUTPUT_SYNCHRONOUS);
    glDebugMessageCallback(debugMessage_callback, nullptr);
    Shader main_shader;
    main_shader.load("shader.vs", "shader.fs");
    Shader filter_shader;
    filter_shader.load("filter.vs", "filter.fs");
    //CUBE VAO
    GLuint cube_VAO;
    GLuint cube_VBO;
    glGenVertexArrays(1, &cube_VAO);
    glGenBuffers(1, &cube_VBO);
    glBindVertexArray(cube_VAO);
        // cube_VAO settings...
    glBindVertexArray(0);
    //OFFSCREEN FBO
    GLuint offscreen_FBO = 0;
    GLuint offscreen_colorTex = 0;
    GLuint offscreen_depthStencilTex = 0;
    GLuint offscreen_stencilTexView = 0;
    int offscreen_width, offscreen_height;
    glfwGetFramebufferSize(window1, &offscreen_width, &offscreen_height);
    glGenFramebuffers(1, &offscreen_FBO);
    glBindFramebuffer(GL_FRAMEBUFFER, offscreen_FBO);
        glGenTextures(1, &offscreen_colorTex);
        glActiveTexture(GL_TEXTURE0);
        glBindTexture(GL_TEXTURE_2D, offscreen_colorTex);
            glTexStorage2D(GL_TEXTURE_2D, 1, GL_RGB8, offscreen_width,
                           offscreen_height);
            glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
            glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
        glBindTexture(GL_TEXTURE_2D, 0); //unbind
        glFramebufferTexture2D(GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0,
                               GL_TEXTURE_2D, offscreen_colorTex, 0);
        static GLenum offscreen_drawBuffers[] = { GL_COLOR_ATTACHMENT0 };
        glDrawBuffers(1, offscreen_drawBuffers);
        glGenTextures(1, &offscreen_depthStencilTex);
        glBindTexture(GL_TEXTURE_2D, offscreen_depthStencilTex);
            glTexStorage2D(GL_TEXTURE_2D, 1, GL_DEPTH24_STENCIL8,
                           offscreen_width, offscreen_height);
        // Attach the depth and stencil texture to the framebuffer
        glFramebufferTexture2D(GL_FRAMEBUFFER, GL_DEPTH_STENCIL_ATTACHMENT,
                               GL_TEXTURE_2D, offscreen_depthStencilTex, 0);
        // >>>>>>  Here the important block
        glGenTextures(1, &offscreen_stencilTexView);
        glTextureView(offscreen_stencilTexView, GL_TEXTURE_2D,
                      offscreen_depthStencilTex, GL_DEPTH24_STENCIL8, 0, 1, 0, 1);
        glBindTexture(GL_TEXTURE_2D, offscreen_stencilTexView);
            glTexParameteri(GL_TEXTURE_2D, GL_DEPTH_STENCIL_TEXTURE_MODE,
                            GL_STENCIL_INDEX);
        // ^^^^^^  Here the important block
        // Check if the framebuffer is complete
        if (glCheckFramebufferStatus(GL_FRAMEBUFFER) != GL_FRAMEBUFFER_COMPLETE)
            throw std::runtime_error("The offscreen FBO is not complete.");
    glBindFramebuffer(GL_FRAMEBUFFER, 0); //unbind
    // WINDOW RECTANGLE VAO
    GLuint wRect_VAO;
    GLuint wRect_VBO;
    glGenVertexArrays(1, &wRect_VAO);
    glGenBuffers(1, &wRect_VBO);
    glBindVertexArray(wRect_VAO);
        // wRect_VAO settings ...
    while (!glfwWindowShouldClose(window1))
        float ratio;
        int width, height;
        glfwGetFramebufferSize(window1, &width, &height);
        ratio = width / (float)height;
        glViewport(0, 0, width, height);
        // Drawing on the offscreen FBO
            glEnable(GL_DEPTH_TEST);
            glEnable(GL_STENCIL_TEST);
                glStencilFunc(GL_ALWAYS, 1, 0xFF); //stencil test always pass
                glStencilOp(GL_KEEP, GL_INCR, GL_INCR); //the value stored in the stencil buffer is increased every time a fragment is not discarded
            glClearColor(1.f, 1.f, 1.f, 1.f);
            glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT | GL_STENCIL_BUFFER_BIT);
            main_shader.bind();
            glm::mat4 view(1.0f); view = glm::translate(view, glm::vec3(0.f, 0.f, -3.f));
            glm::mat4 projection = glm::perspective(glm::radians(45.f), 800.f / 600.f, 0.1f, 100.0f);
            glm::mat4 model(1.f);
            model = glm::rotate(model, glm::radians(static_cast<float>(glfwGetTime() * 20.f)), glm::vec3(1.f, 1.f, 0.f));
            main_shader.set_mat4("model", model);
            main_shader.set_mat4("view", view);
            main_shader.set_mat4("projection", projection);
                glDrawArrays(GL_TRIANGLES, 0, 36);
        // Drawing on the default FBO
            glDisable(GL_DEPTH_TEST);
            glClearColor(0.f, 1.f, 1.f, 1.f);
            glClear(GL_COLOR_BUFFER_BIT);
            filter_shader.bind();
                glDrawArrays(GL_TRIANGLES, 0, 6);
        glfwSwapBuffers(window1);
        glfwPollEvents();
    //Destroy the window and shut down GLFW ...
Expected Results:
I expect to access the texture in the fragment shader and use the actual values stored inside.
Actual Results:
Black screen. I can't access the actual values of the texture in the fragment shader. I got only zeroes.
