23587 Discussions
graficos intel hd 520
mamer
hola. tengo un pc con una grafica intel hd 520, cuando lo conecto a mi tv no detecta señal hd, alguien sabe como configurar esto para que el pc emita hd y el tv detecte la señal hd?
MUC
Honored Contributor I
Please specify which device (brand and model) you are using and which cable you want to use to connect it to the TV.
mamer
El pc es un portátil hp EliteBook 840 G3 14" Core i5 2.4 GHz - SSD 1000 GB - 16GB . El televisor es un PHILIPS 50PUS7609, Ultra HD 4K, HDR10+ y el cable es de la marca hama 4K@60Hz ULTRA HD.
Si necesita mas información, dígamelo por favor. Gracias por su interés.
MUC
The laptop is an Intel Skylake platform (6th Gen).
HP EliteBook 840 G3 Notebook PC - Maintenance and Service Guide
There are apparently different versions, but all have a DisplayPort Dual-Mode (DP++) connector:
This means that you can plug a (cheap) passive cable from DisplayPort to HDMI, but this has the limitation that only the bandwidth that the processor can deliver with the HDMI protocol is available. In this case, 300 MHz TMDS (theoretically 4K @ 30 Hz).
However, the processor can also output the DisplayPort 1.2 HBR2 protocol. So if you use an active cable that acts as a protocol converter, it should be possible to get a resolution of 4K @ 60 Hz on the Philips 50PUS7609.
Please note: HDR is not supported by Skylake processors.
I would recommend one of the following active cables (DisplayPort > HDMI). They should work plug and play. If not, please use the relevant hot key to switch the screen image among display devices connected to the system. If the TV is connected to the computer, pressing and holding Fn (at the bottom left) + pressing F4 shortly (at the top of the keyboard with monitor symbol) will alternate the screen image from laptop display to the TV. On repetition to both. Or back.
mamer
Bueno. Lo he dejado por imposible y ahora estoy probando con éste: lenovo 330-15IKB (Tipo 81DC) Computadora portátil (ideapad) - Tipo 81DC. La gráfica es una 620
MUC
