- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
what driver am I supposed to use with the above CPU for windows 10 x64
installed a new computer, brand new installation, downloaded drivers from motherboard manufacturer supermicro, did not work, claimed that my computer does not meet the requirements.
If I try a 32-bit version it tells me it's the wrong one.
downloaded 4-5 different versions of the drivers from Intel download center, but nothing works.
manuallt updating the driver to the intel driver does not work as windows either says the "default " driver is better, or that the intel driver is not suitable.
All ideas welcome
Jan Mattsson
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Check out: http://ark.intel.com/de/products/88170/Intel-Xeon-Processor-E3-1235L-v5-8M-Cache-2_00-GHz# @downloads Intel® Xeon® Processor E3-1235L v5 (8M Cache, 2.00 GHz) Spezifikationen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I managed to figure out the reason and it is not driver related.
The motherboard (supermicro X11ssl) has a built-in GFX (ast2400) and the device that shows up is this GFX, not the built-in one, (windows doesn't know about it so it gets the default vga driver, and this is irrespective of bios settings.
for some reason the X11ssl does not support the built-in intel graphics, and can therefore not be used for applications requiring quick sync
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello everwake:
Correct, if the motherboard has a built-in video card, then in that case the graphics from the processor get disable, the video card is the one that will support everything related to graphics, and in order to make it work properly, the drivers that are needed are the ones that belong to it.
Since this is a built-in video card and not an external one, the graphics drivers that are available for the board should work for this PC.
On the following link you will be able to get the drivers for your motherboard:
https://www.supermicro.com/support/resources/ https://www.supermicro.com/support/resources/
Alberto
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
