23795 Discussions
graphics driver not installed
bb69
hello, help me figure out the error when manually installing the intel graphics driver...
n_scott_pearson
Please provide us with a full description of your system. Download and run the Intel System Support Utility for Windows. Select *all* data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog (below the edit box for the body of your response post), upload and attach this text file to the response post.
bb69
большое спасибо за ответ но я решил откатить систему назад и все стало нормально ,думаю проблема была в обновленных драйверах...еще раз спасибо за помощь.
